difference betwee Cand Super C
Ron Fink
05-11-2005 17:30:34
HOW DO I TELL THE DIFFERENCE BETWEEN A C AND A SUPER C ?
Van in AR
05-12-2005 11:43:13
 Re: difference betwee Cand Super C in reply to Ron Fink, 05-11-2005 17:30:34
Does it have a water pump? If not its diffinatly a C.
Van
Nat
05-12-2005 07:24:31
For one thing, you can tell by the serial number. A plain old C will have a serial number below 100000. Super C has a serial number above 100000.
Glen E.
05-12-2005 00:24:50
The C has drum brakes, the super C has disc brakes. The Super C radiator is a couple of inches taller. There is about 2 inches of gap between the hydraulic lift and the gas tank on the Super C. The gas tank on the C sits right on top of the hydraulic lift.
CNKS
05-11-2005 17:39:10
Several hundred posts in the archives -- you can do a search. However, without listing all the differences (someone will), on a C the brake and clutch pedals are straight, on a Super C they are curved back toward the operator. This difference can be seen with a quick glance, the others require closer inspection.
