UC 200 engine
WayneT
05-11-2005 19:07:12
I have a chance to buy a large compressor that runs a jackhammer. The compressor part is shot. It has an International Harvester UC 200 engine. I can't find out much about it. It looks to be the size of an M engine or so. Does anyone know anything about them (Yr-HP, etc)or were I could find out?
Thanks
El Toro
05-12-2005 08:21:31
 Re: UC 200 engine in reply to WayneT, 05-11-2005 19:07:12
Why don't you rebuild the engine on the M that has removable sleeves and new sleeve and piston kits are available too. Hal
George 2
05-11-2005 19:59:59
The C200 is the original equipment engine for a 544, 574, and 674 gas tractors. It was also used in a windrower (275 or 375?)
ChadS
05-11-2005 19:43:44
The serial tag should give the engine make,, I have an air compressor for parts that has a C-200 engine in it, and all it is, is a 4cyl version of a 6 cyl, same bore and stroke as the 806 C-301. Rated at 2800 rpms, 70hp for the one I have. Hope this helps,, Chad
WayneT
05-11-2005 19:52:27
 Re: UC 200 engine in reply to ChadS, 05-11-2005 19:43:44
Thanks... total numbers are UC-200 JOY LQ-22A.
How much trouble you think to put in a Farmall M to a 450, or what else might it fit?
Hugh MacKay
05-12-2005 02:04:30
 Re: UC 200 engine in reply to WayneT, 05-11-2005 19:52:27
Wayne: I wouldn't waste my time on this engine. One of IH's non sleeved engines, probably by now has had all the rebuilds it can take. It will never measure up to M or 450 original engines either.
ChadS
05-11-2005 19:43:40
