Re: Farmall A crankshaft belt pulley
john *.?-!.* cu
05-12-2005 10:22:39
Looks like my puller is getting around. Be careful heating the pulley to hot when reinstalling, remeber it is sliding into a seal. To help pull it into ploace, screw a piece of threaded rod into the center of the crankshaft, and get a pieco of pip that will fit against the pulley oustide the crank ears so it will pull even ly, plus some washers and a nut. Use that to help pul the pulley into place.
El Toro
05-12-2005 12:40:46
 Re: Farmall A crankshaft belt pulley in reply to john *.?-!.* cub owner, 05-12-2005 10:22:39
Hi John, When I restored an A, that pulley wasn't that hard to remove or to reinstall. From what I've read on this forum the Cub's pulley is very hard to remove and can be damaged easily if the pulley is gripped by the outer edge where the metal is thin. I've added one of each to my tool collection in case I ever need it. I would need a crane to load that tool box now. You can not beat that hydraulic pressure when pulling or pressing. We haven't had very warm weather here in MD so far this spring and it's dry again. Hal
