oil level in air cleaner oil cup, farmall H
arod
05-12-2005 11:16:29
when I am turning my engine over while timing it, that oil cup is gurgling loud. I filled to the line level, just don't want oil to be sucked into the air intake into the carb and create a bad mess. Is the gurgling sound normal to hear then at proper level?
RustyFarmall
05-12-2005 13:59:19
 Re: oil level in air cleaner oil cup, farmall H in reply to arod, 05-12-2005 11:16:29
If by any chance you are turning the engine backwards it will create some strange suction like sounds.
arod
05-12-2005 14:24:50
 Re: oil level in air cleaner oil cup, farmall H in reply to RustyFarmall, 05-12-2005 13:59:19
ha ha, that is it! I have been turning the engine over by hand, using the fan blades. I have been pulling down on the distributor side. oops, that is the wrong directions isn't it! ha ha
Nat
05-12-2005 12:34:10
Sounds like your intake valves are open when the pistons are on the UP stroke.
You're timing this engine from a complete disassembly, right?
arod
05-12-2005 12:37:46
 Re: oil level in air cleaner oil cup, farmall H in reply to Nat, 05-12-2005 12:34:10
yes, complete disassembly. Had the head rebuilt at a machine shop.
Nat
05-12-2005 14:21:37
 Re: oil level in air cleaner oil cup, farmall H in reply to arod, 05-12-2005 12:37:46
Have you adjusted the valves yet? It might not be timing, just that the valve lash is set way too tight and the intake valves aren't closing completely.
captaink
05-12-2005 11:59:23
I agree, it is not normal. If you fill the air cleaner with oil to the line on the cup you will not have a problem with it getting in the carburetor and making a mess.
Van in AR
05-12-2005 11:41:04
No not normal, its backfiring through the oil.
Van
