o/t- cushion hitches
scot_c
05-12-2005 21:16:26
I'm wanting to put a receiver hitch on my pickup, and I was wondering about getting a cushion insert. Does anyone here have any experience with them? We've got a cheapo cushion insert from TSC that seems to help a little on our plowtruck but I was wondering if the $200+ pricetag on a shuck is worth spending. Any opinions?
David A. Hodson
05-13-2005 04:41:57
 Re: o/t- cushion hitches in reply to scot_c, 05-12-2005 21:16:26
I have a DMI cushion reese class V hitch on my truch to pull wagons and trailers, and I wouldn't have anything else. David
scot_c
05-15-2005 19:27:13
 Re: o/t- cushion hitches in reply to David A. Hodson, 05-13-2005 04:41:57
I've got a 1500 and no one sells a calss v for a dodge anyhow. You have a DMI brand insert? How much do they run I'm looking at $200 for a shuck.
David A. hodson
05-15-2005 20:03:59
 Re: o/t- cushion hitches in reply to scot_c, 05-15-2005 19:27:13
Its not an insert its a regular DMI frame mounted cushion hitch but instead of a drawbar its a reese. You should be able to get the frame even if you have to make the brackets but it'll more-n-likely be more expensive the the shuck. David
scot_c
05-15-2005 20:08:33
 Re: o/t- cushion hitches in reply to David A. hodson, 05-15-2005 20:03:59
I think I get it, it's a cushioned reese hitch, so any insert you use is cushioned? I also take that back draw-tight makes a classV
Chris in Washington
05-12-2005 23:58:36
I have a Ford F-250 diesel that I use to tow a 10,000 lb equipment trailer. This is the main hauler for my tractors and I use a cushioned hitch. Before I bought the cushioned hitch I could really feel the trailer on rough roads. The cushioned hitch smoothed things out, so I feel a nudge instead of a slam. I don't remember the make of my insert, but it has urethane bumpers, and I grease the insert so it can slide easier.
