Spark Plug and Distributor Configuration for Farma
Bill Peedle
05-13-2005 11:06:39
I made the mistake of putting a 12 volt charger on a 6 volt battery and fried my wiring,ignition system coil; etc.I replaced all the parts and converted to a 12 Volt electrical system but here is my problem. I messed up and didnt mark the distributor wires to the plugs so I dont know what wire goes to what plug or what wire goes to what hole in the distributor. I have a Farmall A 1942, 4 Cylinder. Also any help in setting the timing would also help me out.Thanks for taking the time to read this and I would really appreciate any help I can get.Bill Peedle wpeedle@ford.com
El Toro
05-13-2005 17:42:38
 Re: Spark Plug and Distributor Configuration for F in reply to Bill Peedle, 05-13-2005 11:06:39
Make sure your points are set at .020" and use a timing light to set the timing with the engine at an idle. Mark the flywheel timing mark with chalk. Hal
MAGMAN
05-13-2005 11:11:59
THE CAP WILL BE CLOCKWISE Rotation STARTING AT ABOUT 1:00 #1 Then #3 then #4 and then #2 the motor is # 1 toward radiator and then 1234 in line going to rear.
