Order Farmall Cub Parts Online
cub drawbar bolts
doc8246
05-13-2005 18:03:57
Are the bolts for the drawbar brackets available from Case IH. Or does anyone have some for sale?
Phlogiston
05-13-2005 18:20:07
 Re: cub drawbar bolts in reply to doc8246, 05-13-2005 18:03:57
Yes, they are available from your Case/IH dealer. They are special in that they have a shoulder to fit the bracket. There are also two sizes depending on the implement. Do not use the longer version if you need the shorter one, as you can crack the housing tring to tighten the bolt in the blind hole.
Phlogiston
