Farmall w/o a cylinder head number
colekicker
05-14-2005 00:01:46
So, I tore into a U-6 I have b/c I am gonna put it in a Farmall M I have. I decided that before I get too far along I would check the top side of the motor. So, I pulled the valve cover to look at the valve train. Well, I was first confused when I saw no oil line across the top. Well, I started looking more closely, and I couldn't see a part number. Looked even more closely and saw, there isn't one. At some point the cylinder head number had been ground off smooth. On another C-264 I have, the casting part number had been ground off and another number had been stamped in place of it. Has anyone ever seen this before? Was this common place practice? Maybe someone knows a little bit more about this.
John M
05-14-2005 05:05:17
 Re: Farmall w/o a cylinder head number in reply to colekicker, 05-14-2005 00:01:46
On the IH repalcement engine,maybe heads too,the engine part number was ground off and stamped.I cant recall why but it seems it was because the engine could be used for several different applications and received and new number,or it was because the engine was nt being used in anything being made at the time or something like that.I have two Ms with repalcement engines,and both have the numbers ground off and stamped on both the block,havent really paid much attetion to it on the head so it may be the same way.
RustyFarmall
05-14-2005 04:30:53
Both of those heads have cracked and been professionaly repaired. The repair was done in the area where the number originally was. In most cases the head number is then stamped at a different location. I would not be afraid to use either of the heads. That "oil" line is not an oil line, it is a part of the ventilation system. I don't know why it's not there.
