casting codes
BillGeer
05-14-2005 10:50:24
Hi Guys Question 1 I have 2 steering bolsters from a farmall A. both have same numbers.one has a square shaft out bottom other has round keyed shaft,Will the insides from one fit in the other? code is 6530 DD.
. Question 2 code on block 6342 DH. If I can find a block with the DH at the end will it fit? Thanks Bill
PS what is the going rate for a block in MI
Jim Becker
05-14-2005 15:36:09
 Re: casting codes in reply to BillGeer, 05-14-2005 10:50:24
Original shaft was square. Round one is a later replacement. The shaft needs to be mated with the correct steering arm. There are no internal differences.
tinyy
05-14-2005 13:41:16
If you want e-mail me and I will give you a number for a guy up by st. Louis mi. that might have one. E-mail is tomntonya@charter.net
Bill Geer
05-14-2005 17:55:41
 Re: casting codes in reply to tinyy, 05-14-2005 13:41:16
Tinyy E-Mail me that phone number. thanks Bill
