IH 2400 B
John Dillard
05-14-2005 11:14:07
Hello, I have a IH 2400B Diesel. I have lost my power steering. Prior to the loss when I would turn my key on, I would hear a pump running before starting the tractor, now I do not hear a pump running before starting. Could this tractor have a Electric Power Steering Pump?
Thank you, a barber not a farmer, John...
JLE
05-15-2005 09:01:55
 Re: IH 2400 B in reply to John Dillard, 05-14-2005 11:14:07
Can't think of any thing that should start from turning on key, unless it has a electric fuel pump. Does it have a Backhoe? or Three point hitch, if so does the swing work on B/H or does three point hitch work???
John Dillard
05-15-2005 17:41:33
 Re: IH 2400 B in reply to JLE, 05-15-2005 09:01:55
Thanks JLE, yes it has a three point hitch as well as bucket on the front, Both Work Well. Also I can raise the front wheels off the ground and the steering works, but there is some noise (did that yesterday) also changed the ign system and the pumps starts now, with turning on the key. But still the steering does not work, with lots of noise when attempting to steer. Thank you, John
