check out farmall C on ebay
Tractor Dan
05-14-2005 15:38:57
check it out Link
scot_c
05-15-2005 18:28:05
 Re: check out farmall C on ebay in reply to Tractor Dan, 05-14-2005 15:38:57
looks legit other than maybe the quick-hitch on a super c? could the outer front axle tubes off an A? rear wheel hubs must be exclusive? what could they have come from, it's got the regular row-crop rear axles
Mike S 806/H
05-15-2005 22:03:52
 Re: check out farmall C on ebay in reply to scot_c, 05-15-2005 18:28:05
The rear hubs are just cut down from the original 36 inch hubs. I measured my super c just have to redrill some new holes. The front looks like the outers from a 2404, 240U or 340U. Also the rear wheels look like the ones on a 2404 6 lug
RustyFarmall
05-15-2005 05:45:47
Tractor has 24 inch rear rubber, typical of an A or B, but not a C. All Cs or super Cs I have seen had 36 inch rear rubber.
CNKS
05-14-2005 18:31:48
Ground speeds are substantially slower. The 5 mph 3rd gear is probably reduced to less 3 1/2 or so. Probably good for a rototiller in 1st. Probably a 7 mph 4th.
farmallkid From Ont.
05-14-2005 15:59:32
By the looks of it, they took some hubs from a smaller tractor, and rigged up an A, or maybe it is a C wf. All painted up it would be a show stopper!
