856 value?
Swampcat
05-14-2005 17:51:47
I'm going to look at an IH 856 with a front loader/bucket. It's running and the loader works. Anything I should look at specifically besides the obvious like, tires, exhaust smoke, brakes, leaks and hose condition? It's been shedded most of its life. It's a bigger model than I need but I'm gonna check it out any way. Any thoughts on what one like this would bring? If I get it I would only use it once in a while for bush hoggin' and whatever the loader will let me do. I'm in South Louisiana and the 856 is considered pretty old and small by local farmers.
sammy the RED
05-15-2005 09:11:37
 Re: 856 value? in reply to Swampcat, 05-14-2005 17:51:47
I know of a 856 that was sold for $7,300 last month.
migraine
05-15-2005 07:28:14
The 856 is a very good tractor with plenty of power to do some bigger jobs but really quite aesy to work in the tight areas as well , We ran a 856 with turbo for many years and did lots of field work and all the planting. Very smooth running engine, Maybe check the shifter linkage and the parking brake lock to see if its had the new kit to tighten it up. Also with the loader on it look for rewelds and tie rod issues . I passed on one last year for 2500 bucks and that ranks as one of my duller moments in buying I.H. A good one with loader should bring 5000-6500. Migriane
RustyFarmall
05-15-2005 04:40:29
Hugh gave some very good pointers, I really can't add to them. Prices for an 856 could run anywhere from under $3,000 for a parts tractor up to over $10,000 for an excellent low houred tractor.
Hugh MacKay
05-15-2005 03:53:43
Swampcat: 856 may be quite old as your neighbors suggest however 56 series tractors have stood the test of time much better than most tractors. The very best tractors IH ever produced, it was all down hill after that. There are 856 tractors around today with 15,000 to 25,000 hours on them and have never been rebuilt.
If I were to return to farming today, I wouldn't be one bit afraid to tackle 500 acres of cash croping with a couple of 56 series tractors.
Having said all of that, you must decide condition of the particular 856 in question. One of the first items I look for in a used tractor is condition of sheet metal. Then look for welding on castings and front end. Those two will tell you a lot on how well tractor was cared for and maintained. If those items are in good condition, tractor rebuilds are quite straight foreward. From there ask for a working demonstration, about 8 hours on a 80% of hp job. If he refuses you know something needs rebuilding, and in 8 hours your going to find it. If the guy consents to the demo, you know he is damn certain of tractors ability and condition.
I go to a consignment auction every year, held by a particular auctioneer. He has rules on selling tractors. All tractors being sold as running tractors must be started by auction staff at 10 am and left running at 800 rpm until tractor selling time at 1 pm. During this time prospective buyers can check them out. All tractors that don't make the 3 hours are sold as non running or parts tractors. You can also consign a tractor as non running, and not bother with the 3 hour test.
Remember when you go to buy a tractor, the customer is always right, it may be his tractor, but it's your money.
