Cast plow shares
Plow Man
05-15-2005 06:11:28
Does anybody know where to buy new cast plow shares for a IH #8 plow and other moldboard parts?
Haas
05-15-2005 16:16:17
 Re: Cast plow shares in reply to Plow Man, 05-15-2005 06:11:28
If you take the shares off, there should be a number cast into the back such as O 554. (I think O 554 is a 14 inch share that is common) Most all the earlier plow shares start with the O (that is the letter O, not zero). There are many different ones, some will interchange, some not, so you need to know your number. I'd suggest putting an ad in the classifeds here on this site when you know the share number you need. Maybe you will luck up and find some new old stock shares. I had some NOS shares, but have sold all but some left hand 16 inch shares, number O 557.
El Toro
05-15-2005 07:48:44
Are there any part numbers or casting numbers on the parts that you need? Hal
