Re: Belly pump gallons per minute
kfox
05-15-2005 07:53:46
Howdy, I've been working on my H bellypump for a few days, and I hve the service manual right here in front of me. According to the book,
At 3/4 engine throtle the folling pump capacity is obtained:
Pressure Pounds, PTO Speed, Oil Temp, GPM
800, 540, 91-98, 7-3/4
700, 540, 101-110, 8-1/3
600, 540, 99, 9.43,
500, 540, 100, 9.73
400 540 100 10.3
Now I have a ?
Is the dipstick susposed to be fastened to the filler cap, or does it set on top of the fill pipe?
I didn't think I had the dipstick, but it was down in the tank with the washer missing. ken
RustyFarmall
05-15-2005 12:18:32
 Re: Belly pump gallons per minute in reply to kfox, 05-15-2005 07:53:46
Some of the dipsticks were attached to the cap, some of them simply sit on top the pipe. I think the older ones were attached to the cap, but I don't know when the change occured. Either way will work. Personally, I find the dipsticks a nuisance, and have removed it.
old
05-15-2005 08:33:59
The H I have the dipstick is hooked to the plug so it comes out when you remove the plug. I think you have a little problem with yours
