Farmall H steering hard, could it be bolster prob?
FmrBoy
05-15-2005 11:29:13
Hey Guys, I have a 44 H that has steared hard for years and I am going to be fixing it up a little before doing a paint job on it. Was told once that there is some kind of a washer that can get squashed in the bolster that makes it difficult to steer. Is this true and how much of a job is it to change out those parts. Thanks in advance.
Bob M
05-15-2005 13:31:07
 Re: Farmall H steering hard, could it be bolster p in reply to FmrBoy, 05-15-2005 11:29:13
Could be the thrust bearing (an axial ball bearing at the bottom of the pivot shaft that bears the weight of the front end) has failed. Or as I found with my Super H the thrust bearing was installed without a required spacer. Stiff steering is the result.
Not difficult to dissassemble/repair, though several of the parts are heavy. You'll need an engine hoist, loader, or similar to handle safely.
Punch below for a few pix from when I did my SH.
FmrBoy
05-15-2005 19:06:16
 Re: Farmall H steering hard, could it be bolster p in reply to Bob M, 05-15-2005 13:31:07
Thanks so much for the pictures and info, this will help tremdously.
Farmall Teen
05-15-2005 11:32:08
Does it fet greased often?
