LowBoy 154 bearings
RickS2524
05-15-2005 13:52:10
I have a 1974 IH Cub lowBoy 154. I'm looking for some information on where I can find the bearing for the two pulleys that the mower drive belt runs on ? I'm not sure what these pulleys are called but they're located at the lower rear frame of the Cub. Any parts numbers would be helpful too. Thanks
El Toro
05-15-2005 14:40:28
 Re: LowBoy 154 bearings in reply to RickS2524, 05-15-2005 13:52:10
I would pull the pulleys and look for a number on
those bearings. Any auto parts store should have them such as NAPA or Autozone. Hal
Bill Geer
05-15-2005 14:19:02
If you are talking about the bearing that has 2 flanges with the bearing in the middle. witch mounts in the ajusting bracket.you can get it at car quest. or farm supply store.it is a one inch I.D.
