Super C Hydro pump
Andrew Z
05-15-2005 14:38:47
I have had hydrolic oil leaking into the engine so today I took off the hydrolic pump off my Super C today. When I took the pump the pump off the drive gear on the pump had a broken tooth and the center of the gear was all egged out. The cam gear had wear on it. But could not find any broken teeth on the cam. Can I get replacement gear for the pump? and do they sell a seal and gasket set for the pump? Where can I possibly get one?? Thanks for the help!
Andrew
CNKS
05-15-2005 19:30:16
 Re: Super C Hydro pump in reply to Andrew Z, 05-15-2005 14:38:47
Case-IH has the seal and gasket kit, doubt if they have the gear, ask anyway. You will need the number off the pump, as there was more than one manufacturer. Mike at Steel Wheel Ranch may have a gear, 785-548-7437.
