Wiring an H
PatBmich
05-15-2005 16:37:50
I need some info on re-wireing an H.
Going to add lights and re-do switches to ignition and so on. What gauge wire do I need on a 6 volt system???
garsewhitlock
05-25-2006 12:51:13
 Re: Wiring an H in reply to PatBmich, 05-15-2005 16:37:50
i need to see a wirein diagram on a farmall h i have to add a push pull ignition switch and know where the alternator wire,s go it dont have a voltage resistorare a voltage regulator i have some wire,s hook and some not hook up and needs replaceing
Larry in CO
05-15-2005 18:38:59
Bob M has some outstanding wiring diagrams that have the recommended wire guage listed on them. Punch below for his photos. HTH. Larry
gene b
05-15-2005 17:37:00
14ga will carry 15 amps so you can go from there.
