400D or 450D ???
JakeF
05-15-2005 18:52:23
I just got a 400 or 450 diesel Farmall. I can read the Serial # as being 19541 but the model markings have worn off. The guy I got it from bought it without sheet meatal, and isn't sure what it is. He got sheetmeatal for a 450 for it that comes with it but I was wondering what little changes IH may have made to the 400-450's so that I can tell what it is for sure. Thanks, Jake
DWV
05-16-2005 11:31:32
 Re: 400D or 450D ??? in reply to JakeF, 05-15-2005 18:52:23
Look at date codes on castings,for that serial #
most should end with letter A if 400 and C if 450.
The engine size and serial # is stamped on left side near front of engine,below head and above injection pump,on flat surface.
CNKS
05-15-2005 19:35:11
The 400 has a D-264 engine, the 450 has a D-281. Should be cast into the right rear of the block, at least the gas versions are.
JakeF
05-16-2005 22:20:27
 Re: 400D or 450D ??? in reply to CNKS, 05-15-2005 19:35:11
It has a D281. Thanks. Jake
