can't read serial number on SM
jnewark
05-16-2005 04:47:51
greetings,
I cant read the entire serial number on my super M, is there some other numbers somewhere on her I could use to identify the year? thanks in advance
jack
Nat
05-16-2005 04:58:27
 Re: can't read serial number on SM in reply to jnewark, 05-16-2005 04:47:51
There's a serial number on the engine that might be fairly close to the tractor's serial number, but the engine could have been swapped out so all bets are off.
There's a date code on all the major castings, which might help you narrow it down to 2 possible years, but since they really only made Super Ms for 2 years, it doesn't help much.
If the battery box is under the seat, it's probably a 1953. If it's under the gas tank, it's probably a 1952.
jnewark
05-16-2005 06:15:26
 Re: can't read serial number on SM in reply to Nat, 05-16-2005 04:58:27
battery box is under the gas tank,, for some reason I thought she was a 1952... thanks
jack
THEkyroastnear
05-17-2005 20:54:52
 Re: can't read serial number on SM in reply to jnewark, 05-16-2005 06:15:26
that is not always the case my super batt. box is under tank but is a 53 model i can read my ser. plate clearly
