mfwd 806 856
w.burrow
05-16-2005 06:45:23
can any one give me some history on the 806 and 856 with front wheel drive, when they were made and how many were made ect. any help would be greatly appreciated.
chadd
05-16-2005 09:31:45
 Re: mfwd 806 856 in reply to w.burrow, 05-16-2005 06:45:23
They were created on the same line as the rest of the 06 and 56 series tractors, just that when they were putting on the front axle, they wheeled the 4 wheel drive axle under it and bolted it down instead of the 2 wheel drive bar axle. If memory serves me correctly, it is an Elwood FWD axle. I have seen a picture where they have an axle sitting on a small jack next to the assembly line to facilitate putting it in a 66 series tractor. I think it was the same with the 56's and 06's. Hope it helps.
MN Scott
05-16-2005 18:59:59
 Re: mfwd 806 856 in reply to chadd, 05-16-2005 09:31:45
I think the 06, 56, 66 series tractors had the American Coleman MFD axles. They did not turn very sharp and were prone to end U joint failure. The Elwoods, a much better engineered axle, were first used on the 86 series tractors.
scot_c
05-18-2005 19:07:12
 Re: mfwd 806 856 in reply to MN Scott, 05-16-2005 18:59:59
I beleive our 1066 has a spicer axle, not sure if it was factory it's got a large welded rail with 4 bolts holding the axle housing to it, looks to be the 2 wheel drive bolster though.
