farmall A electric.
tractor-ernie
05-16-2005 16:57:14
I have a farmall A that i just put a new regulator and generator on. I have polarized it(no spark as I usually get on my fords)??? However, it only discharges. I have one terminal to bat, one to field and one to amature.What can I do? Tests? grounds?
Janicholson
05-17-2005 10:54:38
 Re: farmall A electric. in reply to tractor-ernie, 05-16-2005 16:57:14
The answer is to check out a book (old) from a local library, on Generator systems. There are also many posts in the archives here for polarizing Gen systems. I believe your described technique is not correct for Delco systems, they require volts to energize the field.
My 2 cnts. JimN
