farmall H, avg Oil Pressure? mine reads 40 at idl
arod
05-17-2005 10:53:53
Curious what is considered reasonable oil pressure on an H.
EricB
05-18-2005 07:15:37
 Re: farmall H, avg Oil Pressure? mine reads 40 at in reply to arod, 05-17-2005 10:53:53
I get worried when people talk about opperating with low oil presure. Nothing wrecks an engine faster than poor lubrication.
I rebuilt my W4 20 years ago and it still reads 60psi at idle and 75/80 working. On a real hot day after 4-6 hours it may drop to 60 at half throttle.
Whats the saying? "Oil is your cheapest mechanic!"
williaf
05-17-2005 15:01:55
Mine starts around 50, after a few hours it might drop to 35. I'm happy.
Wm
Allan in NE
05-17-2005 13:20:17
Don't know what they are "sposed" to have; my old clunker runs right at 60 lbs cold, hot, slow or fast. :>(
Allan
third party image
Andy Martin
05-17-2005 15:46:28
 Re: farmall H, avg Oil Pressure? mine reads 40 at in reply to Allan in NE, 05-17-2005 13:20:17
With all due respect, I don't think you know what "clunker" really means :-)
captaink
05-17-2005 13:05:42
If that is at a slow idle, you are good to go for a long, long time.
Nat
05-17-2005 11:01:05
That's darned good oil pressure in my book.
Gary The Rookie Farmer
05-17-2005 15:08:41
 Re: farmall H, avg Oil Pressure? mine reads 40 at in reply to Nat, 05-17-2005 11:01:05
Can oil pressure be too high?
If so, what would cause it and how would you fix it?
Steven@AZ
05-17-2005 19:56:49
 Re: farmall H, avg Oil Pressure? mine reads 40 at in reply to Gary The Rookie Farmer, 05-17-2005 15:08:41
Yes, oil pressure can be too high - usually the result of a bad relief valve in the pump.
H's and M's spec for oil pressure is 75 psi.
My H runs 75 psi at idle cold, 65 psi at idle hot, 70 psi full throttle hot. That is on a complete major overhaul (cut crank, etc.)
Oh yeah, anything over 20 psi at idle hot is perfectly fine for these old beasts!
Steven@AZ
05-17-2005 19:56:21
