how to install an OEM voltmeter on my Farmall H
arod
05-17-2005 11:13:02
I am just dense when it comes to electricity. Purchased a nice voltmeter for my H, and want to wire it in. Where should I connect the leads?
gene b
05-17-2005 19:02:35
 Re: how to install an OEM voltmeter on my Farmall in reply to arod, 05-17-2005 11:13:02
What good is the voltmeter going to do? You should have an ammeter in the charging system not a voltmeter.
arod
05-18-2005 14:49:41
 Re: how to install an OEM voltmeter on my Farmall in reply to gene b, 05-17-2005 19:02:35
Ever noticed how that way too large scale ammeter barely moves? My opinion a worthless guage, more of junction block, ha ha. Voltmeter will indicate more accurately what my alternator is putting back into the battery.
Bob M
05-17-2005 11:44:24
Arod - If your tractor is negative ground, connect the voltmeter "+" terminal to the switched (coil) side of the ignition switch. Connect the "-" terminal to a good ground.
(For a positive ground system simply reverse the connections at the voltmeter...)
Andy Martin
05-17-2005 15:44:56
 Re: how to install an OEM voltmeter on my Farmall in reply to Bob M, 05-17-2005 11:44:24
Are you sure he didn't buy an ammeter?
Bob M
05-17-2005 18:47:56
 Re: how to install an OEM voltmeter on my Farmall in reply to Andy Martin, 05-17-2005 15:44:56
Nope! (My wiring instructions will NOT work for an ammeter...)
Farmered
05-18-2005 04:56:03
 Re: how to install an OEM voltmeter on my Farmall in reply to Bob M, 05-17-2005 18:47:56
OEM stands for original equipment manufacturers. No such thing as an OEM voltmeter on an H. They didn't have volt meters. Ed
Andy Martin
05-18-2005 05:30:10
 Re: how to install an OEM voltmeter on my Farmall in reply to Farmered, 05-18-2005 04:56:03
OEM is also an aftermarket parts co that sells replacement ammeters.
Allan in NE
05-17-2005 11:25:24
Arod,
Just connect it across system voltage.
Allan
Rexalot
05-18-2005 12:14:02
 Re: how to install an OEM voltmeter on my Farmall in reply to Allan in NE, 05-17-2005 11:25:24
An ammeter would be wired in between the battery and the alternator/fuses. (The starter circuit shouldn't be run through it)
Voltmeter would be between the battery and a ground.
I would break the circuit of either with the key. If I had a picture I'm sure I could explain it much simpler.
