Super-A ????????
560puller
05-17-2005 16:25:26
Hey all you Super-A guys I just added one to my collection and since I come from the bigger ones anybody got any words of wisdom,do's don'ts?It came with a pretty good set of cultivators which I have no use for and will take off.It's gonna get a belly mower for my big yard.Well ya'll take care.Eric from Ky
Sam in NJ
05-18-2005 06:11:46
 Re: Super-A ???????? in reply to 560puller, 05-17-2005 16:25:26
I use my Super A as a mower for my big yard too and I love it. Really has a tight turning radius that's even better than some of the so-called yard tractor lawnmowers that are built for the purpose.
Not much in the way of dos and don'ts really, it's just like any other tractor. Check the oil before you fire her up and make sure you keep the belts tight. You'll want to run in 2nd gear full throttle for mowing - I think 3rd gear is too fast. Also, I switched to turf tires on the rear and implement tires on the front so as not to tear things up too badly.
If you need help with the mower hook-up, I have pics I can send you. Good luck!
Sam :)
