i464 brake problems
Tim Carter
05-17-2005 20:44:44
I have a 1977 IH 464 gas burner with no brakes. I was bushoging Tractor ran out of gas backfired sevral times and then quit. I filled the tank up started the tractor, ran fine but no brakes. I checked the flow of the pump. Looked at the hose thatfeeds the brakes hydro fluid had some type of strainer-check valve in it Blew it out it was fine. Also transmition was getting very hot did not know if oil cooler was working but it was. I still can't get any pedal Tried to bleed brakes no luck Ifeel the mastercycl's are good any suggestions?
JB2
05-18-2005 15:32:16
 Re: i464 brake problems in reply to Tim Carter, 05-17-2005 20:44:44
Hi Tim, the transmission running hot in hot weather is normal for these tractors. If it is 80-90F and you are doing heavy PTO work the transmission will get so hot that you can't hold your hand on it.
As for bleeding the brakes or repairing them search the archives under 454,574,674,584,684
they all have the same rear end and braking system.
Good luck
JB2
