M reverse gear
BKing
05-18-2005 08:46:56
A buddy has an M that stuck in reverse. He pulled the shifter off to allign the shifting bars but cannot seem to move the one that controlls reverse even with a pry bar. Does he need a bigger hammer. Any suggestions would be great. THANKS.
Nebraska Cowman
05-18-2005 09:56:02
 Re: M reverse gear in reply to BKing , 05-18-2005 08:46:56
I wouldn't get too rough with it. you will just bend the shifting forks. Mabe jack up one wheel and rock it a little. Or is it stuck from rust and long time resting? In that case you may need to remove the cover
Janicholson
05-18-2005 10:47:46
 Re: M reverse gear in reply to Nebraska Cowman, 05-18-2005 09:56:02
Cowman is on track, If the tractor is in a bind, on a hill, or on a chip of rock the pressure on the teeth can prevent movement of the gear on the shaft.
LOL JimN
