bleeder screws on a 454 ??
pat,maplehillfrm
05-19-2005 20:26:21
any one know exactly where these are?I have a manual it says it is on the rear of the axle but shows no pictures, I have a loader on this tractor so it is harder to see in the rear of the tractor, any ideads where I would look to find these, I have looked but couldnt find anything, when I presson the brakes I get a very spongy feel to the pedal and no stopping at all, thanks pat
farmallkid1958
05-20-2005 18:56:26
 Re: bleeder screws on a 454 ?? in reply to pat,maplehillfrm, 05-19-2005 20:26:21
We had a 584 which was the next generation newer of tractors. the bleeder valve for the brakes was just about 1 inch or so above where the rear axel housing bolts to the rearend housing. it looks like a bleeder on a car or truck. its not very handy to get to, and it might be covered with dirt and you might not be able to see it. but with the tractor running crack it open and bleed it like you would bleed a car. open the bleeder then press the pedel down and then close before releasing the pedel. repeat untill all air is out. hope this is of some help to you.
pat,maplehillfrm
05-23-2005 20:30:27
 Re: bleeder screws on a 454 ?? in reply to farmallkid1958, 05-20-2005 18:56:26
thanks for the reply, I have been busy so didnt get back to you or look yet but there is plenty of dirt there even after clearing most, I will get at it with a pressure washwer and hopefully see it, I appreciate the comeback,pat
El Toro
05-20-2005 06:12:40
The bleeders are usually on the wheel cylinder for
drum brakes and on the brake calipher with disc
brakes. Sounds like you have air in the system.
Could be low on fluid too or both. Hal
