686 injector stuck
Mapleridge
05-21-2005 13:21:52
I am pulling the injectors on the D312 to replace the seal rings but I have two stuck. They both had a little leak by and there is a black build up around the injectors. Any ideas? do they make anything that disolves this stuff? Thanks
MN Scott
05-21-2005 20:20:59
 Re: 686 injector stuck in reply to Mapleridge, 05-21-2005 13:21:52
You should have your coolant drained too, in case a nozzel sleeve comes out with the injector. Just soak it up with carb cleaner and penatrating oil and keep working at them, you'll gettem. Good luck!
Ratchet
05-21-2005 15:54:45
Carb cleaner will do it.
