6 volt Farmall 130 not charging
KMG
05-21-2005 19:18:09
Hi, I have a 130 Farmall with the 6 volt electrical system. It is not charging the battery like it should. I have heard there is some way that you can ground a wire to get it to start charging the battery more. I was wondering if anyone can give me more details or a solution.
Bob M
05-22-2005 06:13:05
 Re: 6 volt Farmall 130 not charging in reply to KMG, 05-21-2005 19:18:09
Punch below for a troubleshooting chart. It'll lead you thru several steps (including grounding the generator field) to determine what the problem is.
Good luck!
El Toro
05-22-2005 05:04:42
I think Hugh has given the best advice to convert to an alternator. Here's a website for an alternator: Hal
http://www.alternatorparts.com/6_volt_alternators_kits_.htm
Hugh MacKay
05-22-2005 04:11:58
KMG: I expect what you are refering to is polarization of regulator. If it is charging some that is not your problem. If you go to archives, do a search for "polarization of regulator" . I'm sure you will find instruction. Been so long since I've done this, wouldn't want to give you wrong info.
If you want my opinion the real problem is your generator needs rebuilding and you need a new regulator. From an economical stand point alternator is the way to go. Rebuilding that old generator, plus a regulator will probably spoil $200. You can probably do a change over for less money and have a much superior charging system.
Two ways of doing this, 1st 6 volt alternator, plus mounting and a system to excite alternator. 2nd 12 volt alternator plus mounting and a system to excite alternator. Same as 6 volt except you now have to change your battery, lights, coil to match 12 volt system.
If you wish to know more about 6 volt alternators, just type that in your favourite search engine. You will find several sources for 6 volt alternators, plus installation instructions. If your battery, lights and coil need replacing anyhow, it will be just as easy to go 12 volt.
I have a SA, 130 and 140, all with alternators. Super A has a 6 volt alternator. The only good reason for that is I had a 1 week old battery when the old generator packed up. I went to a rebuilder, asked how quick he could get me going. He said, "Quick in rebuilding that old generator is two weeks as I don't have the parts to rebuild it. Quick for a 6 volt alternator will be 5 minutes as all I need do is change one wire in a new GM Delco alternator, to make it 6 volt." That was 12 years ago, and the system works perfect. My 130 and 140 are 12 volt, I live in Canada and in sub zero weather, my old Super A is still the best starter, 130 is close. If you have any questions send me an e mail.
El Toro
05-22-2005 03:50:08
You need to hook a a volt meter across the battery terminals and see what your voltage is
with the engine at 1/2 to 3/4 throttle. Should be around 7.5 volts. Make sure all wire and battery connections are clean and tight. If the voltage is ok you should check the electrolyte
(battery juice) for state of condition with a hydrometer. Battery could be getting weak. Hal
