Rear Tire size on Farmall C
Rexalot
05-22-2005 07:25:40
What is the correct rear tire size for a Farmall C tractor? Mine has 1 9.5 x 36 and 1 11.25 x 36.
I would like to match mine up to one size or other.
Thanks.
gene b
05-22-2005 08:06:05
 Re: Rear Tire size on Farmall C in reply to Rexalot, 05-22-2005 07:25:40
Check your rims for width if it measures 10 outside measure it is a 9 as the inside is always 1in smaller and the smaller measure is what you will want to know for tire size. Your 11.5 should say what size rim it should be. The 9.5 sounds like small but if your rim is an 8in it would be correct. Which size do you think looks the best. Your tractor tire dealer can help also. Is the tractor for show or do you need the extra traction.
Rexalot
05-22-2005 12:39:42
 Re: Rear Tire size on Farmall C in reply to gene b, 05-22-2005 08:06:05
I like the 11 inch rubber best, reminds me of my H tractor. I'll measure the rim width. Thanks.
This tractor is mostly for show, maybe pull a hay wagon or spreader.
VirginiaBill
05-23-2005 05:07:35
 Re: Rear Tire size on Farmall C in reply to Rexalot, 05-22-2005 12:39:42
Both my C's have the 11.2x36's although between them there are 4 different brands/tread designs.
