C or Su C Pistons and sleeves
Mike in Shenado
05-23-2005 11:24:59
My Su A block is busted so I found another one from a C or maybe a Su C. Casting # is 354898R2 and FCM 169382 on the #1 cyl machined surface. Is it a 113 or a 123 cu.in.??? Want to put the 3-1/4 pistons in it for belly mower torque.Looking at this web sites parts store,they show a #pk159 for $267 then a R2398 for $401...whats the diff price for?? Is the latter step or fire flow or flat top? Also,somewhere in the parts list they refer to a lower sleeve bore of 3.11 or 3.4 something mine is the bigger,with sleeve removed. Course you fellas may think 3-1/8 stuff will give better power,I don,t know
Mike in Shendoah Valley
05-24-2005 14:02:41
 Re: C or Su C Pistons and sleeves in reply to Mike in Shenadoah Valley, 05-23-2005 11:24:59
Thanks guys for the help, was glad to find out its a SuC block
El Toro
05-23-2005 15:04:07
If that's a C123 block you can use either 3.125",
3.1875" or 3.250" sleeve and piston kit's. I would measure the lower section of the block bore
to be sure you know what the measurement is. I would check around for price quotes and what's included. Some kits include gasket set, main and rod bearings and sleeve and piston kits. Here's
a toll free number for a company that offers that
packaged deal. 1-800-992-5346. Hal
Dave_Id
05-23-2005 14:01:04
The 354898 R1 or R2 is the Super C, 123 Block... I can't answer any of the other questions for you though.
