serial # ?/power steering
Farmall43
05-23-2005 11:37:21
Just bought what was sold as a 350. Got it home and check serial #. It is a 56 300. Double checked this against the block C-164. yep definatly a 300. Question is the suffix on the serial tag is SJ. What does that stand for? Also there is an after market power steering uniton it. It is not plumbed into the existing hydrolics. It has its own resevouir and runs off the same pully as the genorater. Any body have any idea about the power steering? Thanks in Advance, Farmall43
DWV
05-23-2005 12:10:45
 Re: serial # ?/power steering in reply to Farmall43, 05-23-2005 11:37:21
S equiped with T/A with provision for indepentent
PTO. J equiped with rockford clutch.Power steering aftermarket, Charr Lynn maybe.If its 300
should have C-169 instead of C-164.
RustyFarmall
05-23-2005 13:10:14
 Re: serial # ?/power steering in reply to DWV, 05-23-2005 12:10:45
Yes, C-164 is super H. C-169 is 300.
