A charge
tractor-ernie
05-23-2005 14:38:12
The battery on my A keeps losing its charge (it's new). I have a new generator and regulator that work and charge. However with the tractor off, I lose charge.
Roy Suomi
05-23-2005 20:29:07
 Re: A charge in reply to tractor-ernie, 05-23-2005 14:38:12
If you have tested the battery and found it to be in good shape.. Charge it and leave it disconnected and retest it the next day. This will eliminate the battery as the problem. If alls well with the battery then you will have to look for a short in the electrical system causing the drain problem..Put a voltmeter from a battery terminal to the battery post, this will show a voltage drain. If it shows voltage with nothing on then there is a short somewhere.. Start to disconnect one circuit at a time till you find there is no voltage draw. When you find it ,the voltmeter will show no draw. Repair that circuit.
Roy Suomi
05-26-2005 20:45:04
 Re: A charge in reply to Roy Suomi, 05-23-2005 20:29:07
Why , Yes I am.....
