1964 706 gas ci?
Mark R. NY
05-23-2005 15:58:49
I just got a 706 gasser (1964) and was hoping someone could tell me what the engines cubic inches are? Also HP and how are they on fuel economy? & any other idiosyncraceis. Thanks in advance!
the tractor vet
05-23-2005 21:48:23
 Re: 1964 706 gas ci? in reply to Mark R. NY, 05-23-2005 15:58:49
They are a good tractor , but like anything else it all dependes on how it was treated when new . The are in the 70 Hp. class and can weight from 8200lbs to over 12000 depending on fluid wheel weights and ft. weights . If tuned properly they are not hard on fuel as some clam i ran a 67 706 with the 291 for 11 years and never thought that it was that hard on fuel and i pulled 4x16 710 I H plow and a 13and half foot disk . If yours has a new stile selonid on the carb there is no adjustment on the fuel and don't mess with it leaning it out can and will burn pistons and valves run the 93 octain fuel only and only Case I H low ash oil . If it is a 263 cu. in. set the total adv. timeing at 22degrees if it is a 291 then 18 degrees at full throttel . give it a good tune up and set the valves and go over them twice and you should be good to go on that end then the next thing is do the compleat clutch trans brake and dump valve adjustment then the T/A linkage if it is hard to get out of gear then go back over the dump valve . If ya have problems get ahold of me i can walk ya thru the whole tractor in my sleep.
caseyc
05-23-2005 20:20:18
i have a '64 706 with the 263 engine. pulling a 4-16 plow or 15' disc it will use 5-6 gallons of gas an hour. cutting hay with a sickle mower, raking or baling it will use 2-3 gallons an hour. playing with the carb can help greatly. the proper adjustment is halfway. turn the screw in all the way then back it out counting the turns till it wants to die. turn it back in halfway. i run mine 1 to 1 1/2 turns in from there when i don't need all the power and it's really easy on gas. i have gotton away with less than 2 gallons an hour set like that. like the others have said they are great tractors if you take care of them.
casey in SD
MN Scott
05-23-2005 18:12:20
The engine's size should be stamped on the left side of the block near the oil filter. RAS is right that a 64 is supposed to have a 263 in it. If you work them hard they burn alot of gas. Also make sure you use 93 or higher octane gas or you will be melting pistons and burning valves if you work it hard. A gasser is ok for light work but heavy tillage should be left for a diesel tractor IMO. Also it would be a good idea to buy a owners manual and service manual, they come in handy at times.
wolfmantractor
05-23-2005 18:06:53
263 ci; 72-73 hp; Not that bad on gas-unless you're working the snot out of it. Don't ever use ether on it or you'll blow manifold gasgets. Nice smooth running engine.
RAS
05-23-2005 16:52:06
Should be a C263ci 73 pto hp.
Spud
05-23-2005 23:18:59
 Re: 1964 706 gas ci? in reply to RAS, 05-23-2005 16:52:06
Mark I got a 64 706 gas with a 301 in it great horse power punched 40 over head shaved. Wide front duals on rear weights fair paint good tin clam shell fenders almost new tires all the way around. dual pto,, good TA,Replaced 190 hrs ago!!! factory 3 point hitch!! Hate to make you feel bad but I can't get $3900.00 for mine and have $6800.00 in it Like they said the shift is lousy, there bulky, there heavy, Wished I had never seen mine!! Hope you have good luck!
