BN mag timing-magman and gene
RobinPA
05-23-2005 16:09:24
Magman and Gene- I found the double dots on my cam gear. They were hard to see but found them. Used the old mag to make a timing mark on the new drive. Didn't try to start it up yet but I think it should be OK. I think new drive gear should be within one tooth of the old. Thanks
RobinPA
05-24-2005 15:28:03
 Re: BN mag timing-magman and gene in reply to RobinPA, 05-23-2005 16:09:24
Bob and Gene- I put in mag drive to match two dots on cam gear. Then found #1 TDC with mag pushed over towards block. Pulled mag out until it tripped. Started it up with a little pop in exhaust. Loosened mag and adjusted and now runs real nice. Better than ever before. With engine at TDC was a little off horizontal position. Maybe this mag drive was import. Would maybe explain why no dots stamped on it and off a bit. Thanks for all your help. I appreciate it.
Bob
05-23-2005 21:33:35
Did you find that the drive slot was horizontal when you were done, as I posted previously, or did it come out different?
gene b
05-23-2005 18:50:09
Good luck wonder why the new gear didnt have the dots i guess they just want to make you think. As always glad to help anytime. gene b
