F-12 Rear spokes fit C ???
railroadgoat
05-23-2005 21:44:04
Will the rear round spoke wheels off an F-12 fit on a regular "C" ?? Both are 36 inch. Did any of the "C""s come with factory round spoke wheels ??
dej(JED)
05-24-2005 09:46:16
 Re: F-12 Rear spokes fit C ??? in reply to railroadgoat, 05-23-2005 21:44:04
The F12 wheels will go on the C axel, but you
would need to shim the axel or weld them to the axel.
dej(JED)
05-24-2005 09:45:52
Jeff Wenner
05-24-2005 09:08:11
I think F-12 axles are bigger.
railroadgoat
05-24-2005 09:20:49
 Re: F-12 Rear spokes fit C ??? in reply to Jeff Wenner, 05-24-2005 09:08:11
I had seen a set of wheels off an F-12 here on YTMAG and it said fits A, B, C and more. So I thought that would be cool to put the round spokes off my parts tractor F-12 on the C. Only problem, parts tractor is in Arizona and I am in California with the C.
Nat
05-24-2005 11:10:29
 Re: F-12 Rear spokes fit C ??? in reply to railroadgoat, 05-24-2005 09:20:49
All the more reason to take everything you read on this site with a grain of salt, or two. Somebody's blowing sunshine up your butt if they're telling you that the same wheels will fit an A, B, C, and F12. The only tractors whose wheels are interchangeable in that list are the A and B.
Ralph L.
05-24-2005 08:01:28
There is a pretty good difference in axle size.
moseed
05-28-2005 06:35:04
 Re: F-12 Rear spokes fit C ??? in reply to Ralph L., 05-24-2005 08:01:28
The axles on the F-12 are larger.
