International 424 Hydraulic Filter
RMB
05-24-2005 17:40:47
I don't have any manuals for my 424.Can someone tell me where the hydraulic filters are on the 3 pt lift?
Hound
05-25-2005 08:57:46
 Re: International 424 Hydraulic Filter in reply to RMB, 05-24-2005 17:40:47
Just like RAS says, its an internal "filter", located in the "rear-end' housing,...sitting on the seat its right below your right walnut. You have to pull it out, by removing the hose and then pulling the steel fitting out. Hound
RAS
05-25-2005 08:29:27
See the line going from the rear deck on the right side to the pump. Where it comes out of the rear deck you will see a hose. The filter is in the rear deck.
