Farmall H tranny
Wayne7
05-25-2005 08:22:06
I have a tooth broken off the constant mesh gear and also the fourth speed gear on the counter shaft of my H. Could a bad bearing have caused the drive shaft to drop down and break off the teeth on the gears. Also, a machine shop said they can build up the tooth, is this a good fix?
Loyd in Texas
05-25-2005 10:54:12
 Re: Farmall H tranny in reply to Wayne7, 05-25-2005 08:22:06
Also a good machine shop can weld the gear up. Since it's fourth I wouldn't worry too much. Make sure you don't have any junk in the case. Get a big magnet and go fishing. Check the pilot bearing and the bearing cage. It's the only roller bearing in the tractor I think, and as it wears it will drop the trans. shaft down enough to cause problems. If you can get salvage gears it would be better, but since the price of steel went up a lot of old tractors went to China.
Loyd in Texas
05-25-2005 10:43:46
The gear shift forks have about four ball bearings and springs [called poppets]. Sometimes due to age the spring will break or the shift levers get wear and the ball drops down into the transmission. This might have caused the broken teeth. If you have the top off they should be checked or replaced anyway. They are still available in the IH dealer hear in Texas.
CNKS
05-25-2005 08:29:22
Possibly a bearing problem. Problem with the machine shop is getting the gear too hot so that it loses it's "hardeness". There are machine shop procedures to avoid this. New or salvage gears may be a better solution, depending on how much you want to spend.
