Farmall H serial # Question.
Bernsy MN
05-25-2005 15:15:22
Found a H today, serial# FBH 40425, would this be a late 53? Thanks for any info, B
Sloroll
05-25-2005 15:18:49
 Re: Farmall H serial # Question. in reply to Bernsy MN, 05-25-2005 15:15:22
I thik 1940 unless you are missing a number sumares..
Bernsy MN.
05-25-2005 18:32:36
 Re: Farmall H serial # Question. in reply to Sloroll, 05-25-2005 15:18:49
Wow, It maybe is a 40, it sure is one clean unit. It has a starter fuel gas tank next to the main tank
Nat
05-26-2005 06:19:14
 Re: Farmall H serial # Question. in reply to Bernsy MN., 05-25-2005 18:32:36
The serial number reference is to the left. Look it up for yourself if you don't believe it.
They made a few Hs in EARLY 1953, but those had serial numbers in the high 300,000s.
That extra tank means the tractor was either a kerosene or distillate model.
