350 u hyralics
jk
05-25-2005 15:46:43
i had an idea the other day. how hard would it be to put a hyrolic filter on my 350 u? i think i could add in a transmission filter like out of jegs, mabee in the return line. any thoughts, oppions, or comments? thanks
jk
05-30-2005 18:24:01
 Re: 350 u hyralics in reply to jk, 05-25-2005 15:46:43
i didn't know about the screen thanks for the thoughts
TDK
05-26-2005 19:39:01
If it's a 350(ser.#13095 & up) it should have the rubber hoses near the pump, making it pretty simple to plumb in a filter. If it has the hard lines from pump to reservoir then it's a little harder to do.
Ibby
05-26-2005 02:33:20
If you have Power Steering, you can filter the return line from the steering box with a unit from TSC or other places. I put a pressure gauge on mine and change the filter when it hits 75psi.
There is also a very small filter INSIDE your safety/regulator/priority valve (power steering or not), that will mess everything up BAD if it plugs. Gotta remove the valve and the end cap to find it.
r4etired
05-25-2005 18:26:38
Unless it has beem removed the tractor already has a filter on it, under the seat in the reservor, a fine screen, maybe 6in long 1-1/2in diameter it is the start of the suction line to the pump
PAULIH300
05-25-2005 16:24:29
You would have to cut into the steel manifold piping,and basically "ruin" what isnt replaceable new.The tranny filter from Jegs/Summit is only around 5/16"-3/8" for the car tranny cooler lines.The Utes steel tubing is a lot larger than that.I really dont think its all that possible on a 300/330/350.
