A
tractor-ernie
05-25-2005 18:11:19
Well, I thought this one would be an easy one for you guys. I have an A that will not hold a charge. I don''t know how to check for a draw on a + ground system. Help?
Joe Kimbriel
05-25-2005 18:22:24
 Re: A in reply to tractor-ernie, 05-25-2005 18:11:19
Lift a battery terminal and stick a small 6 or 12 volt lamp (whatever battery you have) between the battery and the battery terminal. If it lights with the ignition switch off then you have a problem with external battery drain. Batteries can have internal drain also which means replace the battery.
