1942 Farmall H tractor - value?
Michael Taylor
05-26-2005 08:09:36
I am looking at a '42 H farmall with a 5' bush hog. Just wondering what the value would be so I dont pay too much. Gas engine, 3 new tires, oil pressure at 80psi, in good condition...may need new brakes soon. Any comments?
thanks, michael
dhermesc
05-26-2005 15:12:10
 Re: 1942 Farmall H tractor - value? in reply to Michael Taylor, 05-26-2005 08:09:36
Depends - what three tires are new? Two back and one front is a lot differant then two front and one back.
A 5' Bush hog tow behind with a single cylinder lift in GOOD shape is worth $800 or more. A tow behind 5' with a crank lift and beat to **** is only worth a hundred.
Farmallkid From Ont,
05-26-2005 13:35:59
I would say inbetween $1000-$1500. I am talkin in Canadian $. I guy has told me a few times. A good running tractor is worth $1000, then you start adding on the extra's, like the new tires, bush hog, belt pulley, wheel weights ect, Hope this helps you out.
brainerd dave
05-26-2005 09:56:10
Tractor Values under Research & Info on the left side of this page is a good place to find historical prices.
