Primer for CIH paint
TKN
05-26-2005 11:06:42
I am about to paint a B Farmall. This is a working tractor, so I am thinking of just using CIH paint. My question is, do I need any particular type/brand of primer to be compatible with the CIH paint? I have some gray Tractor Supply primer, would it work ok, or do I need soemthng else?
Thanks!
Jim Lockhart
05-27-2005 22:13:33
 Re: Primer for CIH paint in reply to TKN, 05-26-2005 11:06:42
We use a automotive self etching primer from the local NAPA store and it seems to work great.
Mike S 806/H
05-26-2005 19:12:02
I use John Deere yellow primer! I think the tractor supply primer will be fine.
MN Scott
05-26-2005 14:45:12
I use the CIH red primer. Your dealer should have it right along side the CIH paint or he can order it for you.
Dixieland
05-26-2005 11:55:10
Hi TKN, That Synthol was a thinner for CIH paint, not a primer. Sorry bout that.
Dixieland
05-26-2005 11:45:29
Hi TKN, I ain't no painter but someone else posted Synthol as a good primer for CIH paint.
