Chuck3 speed of hydraulics.
Aces
05-26-2005 11:51:08
Chuck. Did you see my post about adjusting the speed of the hydraulics. I should have added one thing if you want to adjust the remotes in this way move the draft lever clear back and it will hold the hitch up, not all the way up but far enough so you can use the tractor with the inside lever down in the offset to adjust the speed of the remotes.
