Transmission fluid IH 444
Kajun
05-27-2005 08:58:59
IH folk:
Is there a filter in the system on a IH 444? I don't mean the one on the hydraulic system. If so, where is it and is there an after market supplier?
Many thanks
Kajun
JB2
05-27-2005 19:32:28
 Re: Transmission fluid IH 444 in reply to Kajun, 05-27-2005 08:58:59
Hi Kajun, IH 444, used regular #80 or 90 wt transmission gease in the transmission and there was not filter as it was not pressure lubed by a pump. The only lubing was done by the rotating gears. Depending if you live in hot or cold climate which wt of transmission grease to use.
#90 wt for hot, #80 wt for cold.
JB2
Kajun
05-31-2005 06:10:39
 Re: Transmission fluid IH 444 in reply to JB2, 05-27-2005 19:32:28
Thanks JB2.
Kajun
