660 farmall
farmallfreak
05-27-2005 10:02:28
Where do I get Info on a 660 Farmall?
im buying one,& I need Info like spec,s on it,
thanks alot,
kirk c,
Harold H
05-27-2005 11:14:07
 Re: 660 farmall in reply to farmallfreak, 05-27-2005 10:02:28
The 660 is a International, not a Farmall. Internationals of that era were; standard/wheel/wheatland/industrial type tractors whereas all Farmalls were row crop tractors. It was produced 1959-1963. The diesel International 660 has the D-282 engine and produced 80.2 pto hp and 71.3 drawbar hp. Shipping weight was 7925 lbs. Ballasted in field it may weigh around 12,000 lbs. The drive train was basicly the 560 rear end with the addition of planatary gears to handle the additional horsepower. It was available in gas, LPG, and diesel versions for fuel, and in agricultural or industrial versions also which mainly differed in; standard color red (ag) vs yellow (ind), different grille, standard adjustable front axle (ag) vs standard non adjustable front axle (ind), and several different wheel, tire, hydraulic, and other options.
Harold H
Leader_03
04-11-2006 19:37:52
 Re: 660 farmall in reply to Harold H, 05-27-2005 11:14:07
We have a 660 Industrial Diesel and I was told that there were only 160 of them made. Is that true? If not, how many were made? Thanks
