bolster seal on 350
jerry davis
05-27-2005 16:36:01
I'm rebuilding the bolster on my 350 rowcrop and have allmost all the parts from caseih but one seal. the lower seal old pt nmumber is 364 468 R91 my local dealer has ordered is twice and both times it comes in with a too small seal. Does anyone have a national or napa number I can use? BTW dumb question time, after reading many posts on this subject, and looking at bob M's pictures, can anybody tell me the correct way to install the lower spacer and thrust bearing? Can't tell from parts breakdown and mine didn't even have some parts in it on teardown. New bearing has numbers on outside should it be installed rightside up or down. bottom spacer flat up or down Thanks Jerry
MN Scott
05-27-2005 18:55:04
 Re: bolster seal on 350 in reply to jerry davis, 05-27-2005 16:36:01
As paulih300 stated that number crosses to CR9876. That seal is for a one inch shaft, I linked to the details below. You must have the wrong IH part number. Get you dealer to look it up again.
PAULIH300
05-27-2005 19:00:01
 Re: bolster seal on 350 in reply to MN Scott, 05-27-2005 18:55:04
That number comes up as a steering shaft seal.
PAULIH300
05-27-2005 16:50:40
CR#9876.
Call your local store and have them tell you the shaft size.
