706 power stering
David Truesdale
05-27-2005 20:53:04
I am having trouble with the power stering on my 706, I have rebuilt the stering block, rebuilt the pump and the stering is still hard to turn, it is loud when turing making a whine the stering wheel is jercking when turing. What else is there to rebuilt on it? (Tractor vet thanks for the info on the shifter on this same tractor it works as good as you said it would.)David
steve aeschliman
05-29-2005 20:16:57
 Re: 706 power stering in reply to David Truesdale, 05-27-2005 20:53:04
max, change the hydraulic filter if it has not beeb changed, a pluged filter will cause a whine and poor steering. steve
David Truedale
06-03-2005 04:34:56
 Re: 706 power stering in reply to steve aeschliman, 05-29-2005 20:16:57
Thanks to all for the info. the power stering is working great. thanks again. David
max adams
05-28-2005 11:48:32
have you checked the orbital valve? they will do the same thing that you have discribed. thats my two cents!
JJK
05-28-2005 08:10:55
Maybe check the pto gear. The splines on the pto gear to the pressure plate could be wore down enough to be slipping and grabbing causing the whine and jerking in the steering. Other symptoms of the pto gear are the remote hyd. and the 3 point would be acting up and the same for the pto.
