340 hyd oil
Gary Cole
05-28-2005 19:03:46
Can anyone tell me where the hyd. oil is checked and added on the tractor. Seems like it would be like my super c with a different hyd. tank. Thanks
PUTTER
05-28-2005 20:10:35
 Re: 340 hyd oil in reply to Gary Cole, 05-28-2005 19:03:46
Gary, You add HyTran fluid to your system by removing the large plug just to the left of the shifter on the trans top. The oil runs the hydaulics and also lubes the trans and rearend. It holds around 10 gallons. You check it by taking out the bolt that is in a plug under the left floor pan, It's kinda hard to see because its hidden by the clutch peddle. You fill it till it runs out the bolt hole. Don't change the oil without changing the hydraulic filter and cleaning the screen. A service manual is a great investment. Good Luck PUTTER
Gary Cole
05-29-2005 04:03:05
 Re: 340 hyd oil in reply to PUTTER, 05-28-2005 20:10:35
Thanks
